I'm trying to create a issue across multiple projects. As these issues are somewhat, I want to create on a single project only and it should replicate across other project at a same time. As these issues are same, it would be save a lot of time rather than creating individually.
I want to do it through automation rules.
Help required.
@Hizkeel Khan Can you please have a look at the following community post and see if it helps.
The above automation set up is creating issues in the same project, you can change this in your set up.
Ojase
