I had like to track on a regular basis, the time tracked for a task in tempo and compare it with the story point of this same task.
How can i do that easily ?
Hi @Patrick Valibus ,
The easiest way I can think of would consist of:
1. Run the following JQL query by using the advanced mode of the Issue Navigator:
"Story Points" > 0 AND Timespent > 0
2. Save your query as a filter.
3. Set the columns to be shown in your filter with at least: Issue Key, Summary, Story Points, Timespent.
4. Export the returned issues to your favorite spreadsheet software and create a column with a formula that calculates timespent column divided by story points column. After that, use a function to show the average timespent per story point.
Hope it helps.
