How to customize Jira Menù Items on a project role base?
Anna Lisa Mazzarese
February 4, 2013
I need to personalize JIRA Menu Items such as the menù that appears clicking on user logged in the upper-right corner, better still if I select items to display based on user information (mainly on project role).
I'd like to do customization using Jira Administration features or PlugIn if possible.
Thank you in advance for any support.
Anna Lisa
Anna Lisa Mazzarese
February 4, 2013
Thanks for the attention. I defined a specific role in my project for users with limited features also on the interface navigation. Is there a PlugIn already available to do this customization (not only add new items, also "hide" standard one) ?
Thank you
MatthewC
February 4, 2013
Not sure this would make sense.... a user can be in different roles in different projects, which one would take priority? You can add new items via a plugin & could possibly use jquery to hide existing items but you would have to be clearer about the logic
