×I am trying to add new fields in the details section of View Issue page. On the velocity page (/4.4.4/WEB-INF/classes/templates/jira/issue/summary/issuesummaryblock.vm) without referring any css file, some css classes are used where i need to do some modifications. I searched the entire workspace for the css classes but i did not find any css files with those classes.
Can you please tell me where the classes used in the vm file located?
Hi Dieter,
Thanks for your suggestion.. I tried arranging the custom fields in the details section and tried for your second approach to add some custom fields under the People and Dates section. The suggested solution is good but i feel difficult to implement. Could you please share more details about the approach like what files need to modify and how to deploy since i have no idea about the speak-easy or classical plugin.
Thanks in Advance.. Srinivas
Hi Jamie,
Will look into it now. Thanks for sharing.
-Srinivas
Have you looked at the docs: https://developer.atlassian.com/display/SPEAK/Speakeasy ?
In the default details section, there are only few fields with two columns and so would like to add other fields like Affects build, Resolver Build, Confirmer Build etc, in a separate colum.
All custom fields are default in the Details section? do you mean adding JIRA fileds to that section? And why do you want to change CSS file when you are not changing the format?
