How to define assignee and issue url in send email of post function?
Hisamitsu Koga
I want to sent email notification with customized Subject and Body to assignee after create new issue.
I think this can be done by Email This Issue post finction in Email This Issue add-on or Send a custom email
post function in Script Runner add on. In case of either case, I want to define the actual assignee name and
issue url in email body. How can I define assignee and issue url? Please provide me with the exact sample / code.
Thanos Batagiannis [Adaptavist]
August 8, 2016
Hi Hisamitsu
If you want to use ScriptRunner's send custom email post function, the body should be something like
def baseUrl = com.atlassian.jira.component.ComponentAccessor.getApplicationProperties().getString("jira.baseurl")
def assignee = issue.assignee?.getDisplayName()
Assignee: $assignee <br>
Issue url: <a href="$baseUrl/browse/<% out << issue.key %>">$issue.key</a> <br>
Also make sure that the post function is after the Creates the issue originally. step
regards,
Thanos
Hisamitsu Koga
Thank you for your answer.
Tarun Sapra
The issue object is already available in the script runner execution context
issue.getAssigneeUser().getDisplayName()
Should get you the assignee's display name and for the URL you can easily construct that again in code
"https://jira.mydomain.com"+"browse" + issue.getKey()
Since "issue" object is present implicitly thus there is no need to import anything it should just work.
Hisamitsu Koga
I want to use Email This Issue post function in Email This Issue add-on. How can I define assignee and issue url? in this case?
Hisamitsu Koga
Never mind anymore. Thank you for your answer.
Tarun Sapra
Please accept or upvote an answer. thanks.
