In the pjs list, when I'm looking on th epj I want to delete, I cannot find the delete field in the list of the projects
To delete both team-managed and company-managed business projects in Jira, follow these steps:
Access Projects:
Go to Projects > View all projects.
Move to Trash:
Find your team-managed project.
Click on the More (•••) menu next to the project.
Select Move to trash. A confirmation dialog will appear.
Confirm by clicking Move.
Permanently Delete from Trash:
Go to Settings > Projects.
Select Trash from the sidebar.
Find your project in the trash.
Click on More (•••) next to the project and select Delete permanently 1.
Access Projects:
Move to Trash:
Find your company-managed project.
Permissions: Only Jira administrators or users with the Administer Jira global permission can move projects to trash and permanently delete them.
Recovery: Projects in the trash can be restored within 60 days. After this period, they are permanently deleted and cannot be recovered 1.
Hi @b.campanale ,
If I got it right, you're trying to delete Jira (business) project?
You need to be Jira administrator in order to do so > you can follow the official instructions.
Basically, in the project list view, click on More actions > Move to trash, which will then send the project to the trash. If you wish to permanently delete the project you can navigate to Settings > Projects > Trash and perma. delete it there (or it will be automatically deleted after a certain number of days).
Tobi
Hello @b.campanale ,
Good day, welcome to Atlassian Community
If I understand correctly, you want to delete a Business Project.
Now based on type of Project, for:
1. Company Managed project: You need to have Administer Jira Global Permission, and you can follow steps mentioned here to delete the project.
To move a project to trash:
Choose Settings () > Projects.
Find your company-managed project and select ••• > Move to trash. A confirmation dialog appears.
Click Move.
Once moved to Trash, follow below steps:
To permanently delete a project:
Choose Settings (), then Projects.
Find your company-managed project and select more actions (•••), then Delete permanently.
2. To delete a team managed Business project: You either need to have Administer Jira Global permission or Project admin role:
Steps mentioned here: https://support.atlassian.com/jira-software-cloud/docs/delete-a-team-managed-project/
