How to disable left buttom corner notification about new issue was created?
When new issue created, popup notification appeared in left bottom corner with X-sign to close. It hides some interface and never goes away. It there a way to anyhow block this alerts?
Thank you.
How to disable left buttom corner notification about new issue was created? When new issue created, popup notification appeared in left bottom corner with X-sign to close. It hides some interface and never goes away. It there a way to anyhow block this alerts? Thank you.
Hi @akssinc -- Welcome to the Atlassian Community!
Short answer: that is not possible with built-in features.
The ability to hide the issue created popup has been requested as suggestions for at least 10 years, and it is always closed as "won't do / fix" by the Atlassian team. Here is a sampling of such suggestions:
Welcome to community :)
We have an open feature request for the same
https://jira.atlassian.com/browse/JRACLOUD-93978
Thank you,
prachi
