×Hi,
I have created a filter which displays issues in a list format which fits the criteria of the filter. One of the columns to be displayed is the linked issues. There is a request to display the assignee of the linked issues as well, but I couldn't find how to. It's not listed in the columns I could display.
I also tried to display the assignee in the linked issue column as an issue could have multiple linked issues.
I was wondering how to change the issue list view so I could display the assignee of a linked issue? It could be in the new column or within the Links column. Below is the screenshot of the page:
Thanks!
Jason
Hi @Jason Yeung you are not able to do it by default. First reason is that Links field can contain more links.
I remember, I implemented scripted field (https://scriptrunner.adaptavist.com/6.20.0/jira/scripted-fields.html) to get similar behaviour, but you would need to install and use ScriptRunner App.
I add my vote to @Martin Bayer [MoroSystems, s.r.o.]
as i can see from your case you have one-to-one link relation. scripted field will be useful for your case
Hi @Martin Bayer [MoroSystems, s.r.o.] ,
Thanks for your help and pointing me to the right direction with ScriptRunner. The scripted field was the way to go.
I got some help from the following video on how to retrieve the linked issues. The person in the video uses ScriptRunner:
https://www.youtube.com/watch?v=cPhDpmSZTE8
Sincerely,
Jason
