How to display custom field for #LookupIssues using smart value?
Rich
October 28, 2020
I have set up automation to send a notification after looking up issues. I'm able to include all built-in issue fields in the email but I'm having difficulty including custom fields.
I looked up the smart value for a custom "Date of Last Status Change" field
"customfield_11180": "Date of Last Status Change",
and then I tried to include the smart value in the email text but it won't display. It looks like the value that Jira returns via the API call is
"customfield_11180": "2020-10-16",
My email text is below:
Below are the current tasks that haven't changed status > 1 week:
<br><br>
<table>
<tr style="border: 1px solid black">
<th style="text-align: left">Assignee</th>
<th style="text-align: left">Summary</th>
<th style="text-align: left">Status</th>
<th style="text-align: right">Last Updated</th>
<th style="text-align: right">Custom field</th>
</tr>
{{#lookupIssues}}
<tr>
<td>{{assignee.displayName}}</td><td><a href={{url}}>{{summary}}</a></td><td>{{status.name}}</td><td style="text-align: right">{{updated.shortdate}}</td><td>{{customfield_11180}}</td>
</tr>
</table>
Any ideas?
Thanks in advance.
Rich
Esther Strom
Welcome to the Community, @Rich
I'm afraid this isn't going to be what you want to hear, but at this time you can't use custom fields with #lookupIssues.
Here's the documentation.
2020-10-28 17_03_39-Automation actions _ Jira Software Cloud _ Atlassian Support.pngA suggestion ticket for this use case was opened in Atlassian's Jira earlier this month. Vote for it, watch it, and hopefully it will be implemented.
Krister Broman _Advania_
January 24, 2022
For Reference to others that are looking for this information
Adding custom fields to Lookupissues does now work for cloud, communicated here:
https://community.atlassian.com/t5/Automation-articles/New-lookup-issues-fields/ba-p/1873978
baoduy August 11, 2021
If we only need to access custom field via a specific item in lookupIssues list, it could able to achieve this by following these steps:
- Use Branch rule / related issues -> Type of related issues: JQL, with search input: key = {{lookupIssues.get(0).key}}
- Access the custom field normally via smart values inside the Branch rule / related issues: {{issue.customfield_10091}} (on my case is multi select custom field))
Screen Shot 2021-08-11 at 18.36.09.pngScreen Shot 2021-08-11 at 18.36.31.pngScreen Shot 2021-08-11 at 18.36.55.png
