×I'd like to display sub-task in the same level as any other user story, as otherwise the design for stories with & stories without sub-tasks is different, making it harder to notice stories with sub-tasks.
However, I can't find on the board how to change the design so it'd be all appearing the same.
See the photo below where MS-8 has different design/ layout than MS-4. I'd like to show all the stories & sub-tasks in the same layout.
Currently I see it like this:
Hi @Anita Kalmane ,
you simply have to modify the swimlane setup of your board.
Board Settings -> Swimlanes -> Select None
Subtasks will be displayed as the other cards as per the following image :
Hope this helps,
Fabio
@Fabio Racobaldo _Catworkx_ , i knew it was possible, just couldn't remember. Thanks, this worked!
