structure Version 9.1.0
The custom issue type appears as I'm using a JQL to show it (insert), . The inserted issue type (JQL) type is not the top level issue type of the Hierarchy. Can I create a transformation that will display the top level issue type and the children of that issue type if the insert (JQL) is not the top level issue type?
Hi @nkmori_rtx_com ,
You decide the hierarchy via the generators on your structure so you should be able to do this.
Can you screenshot the current automation (generator) you have configured?
Here is a walk through of how to create hierarchies: https://help.tempo.io/structure-dc/latest/generators
br
Lisa
