I am trying to move bulk issues from a Agility based project to Scrum Template based project but unable to find options mentioned in help documents.
In Agility when I hit search on board it never show me ... menu and options
I found the answer i have to go in issues and filters where I search for Source project issues and then select option in top right corner for movement as bulk operations.
Glad you found your answer, but sorry to see you go! I guess there was something missing in Agility?
Yes, I need to create new boards for Agility with custom filters, but this is not possible.
