  • Community
  • Products
  • Jira
  • Questions
  • How to do calculation on the issue form in JIRA (without using JIRA Misc Custom Fields) the or calculation on the page in Confluence?
Karmen Cheung May 8, 2016
How to do calculations on the issue form in JIRA (without using JIRA Misc Custom Fields since I use the cloud service only and it only supports server platform) or do the calculations on the page in Confluence?
CelesteCS
Hello, Karmen!
For any calculations in Confluence, including any manipulations with table data and output of third-party macros, like JIRA Issues macro, you may use CelesteCS Math for Confluence.
Assume you have a table with three columns and three rows on your page – from A1 till C3, where row 1 is the header row. The sum calculation formula for rows 2 and 3 will be simple:
SUM(Table1.A2:C3)
There is a plenty of other functions in the macro, so you may perform any calculations using formulas in EXCEL style.
Thanks!
Nic Brough -Adaptavist-
May 8, 2016
You'll need to find or write a "connect" add-on to provide that - I'm not aware of any that do it at the moment, but have a look at the marketplace.
