How to edit / delete labels from Jira project
Jacek August 14, 2024
Hi everyone!
In the Jira project settings I have Issue types and there each issue has a field: 'Labels'. In the past I created a list of labels and now I want to add or edit existing ones. However, I cannot find the option to do this. Could you help, please?
Thanks!
Jacek
Prachi Bolar
August 14, 2024
Hi @Jacek
Welcome to the Community!
Please refer to this KB on how to delete labels : https://confluence.atlassian.com/jirakb/how-to-delete-a-label-in-jira-297667646.html
Thank you,
Prachi
Michel Neeser
Hi @Jacek and welcome!
To delete a label in Jira, you need to remove it from every issue referencing/using the label. You can check the usage of a label with the following JQL query:
labels = LABEL_NAME
Let me know if this helps!
FREE
