How to edit project roles on a project
Elena Rumyantseva
September 21, 2018
I created a new project and in permissions allowed people on my team to browse it and be assigned to issues. However, when I go to the "project settings->people" and choose to add people, it allows me to only assign them to the admin role. How I can add more roles to the project, so it allows me to add people to the project with other roles?
2 accepted
Joe Pitt
It sounds like you haven't defined more project roles. Project roles are universal, not defined by projects.
Pete Singleton
September 21, 2018
You need to define the Project Roles under the Admin area.  Go to Administration -> System, then under the "Security" heading you should see Project Roles
Elena Rumyantseva
September 21, 2018
Thank you!
Like Iman mohammadi likes this
Pete Singleton
September 21, 2018
Can you mark the answer accepted if it works? :-) Thanks
