from watching https://www.atlassian.com/webinars/software/roadmaps-in-jira-software, I understand I should be able to enable the Road Maps feature for Classic Projects.
Can you confirm that I have understood that correctly ?
Can you confirm how I enable that feature ?
Thanks in advance,
matt
Yes. You can do this under the board settings.
pulling back into a single thread...
I see...combined board. Unfortunately I have not clue as it is totally new to me. You might request support from Atlassian Support directly. However, being Beta I would not be surprised that it isn't supported yet.
unfortunately this is not the case in our "combined board". Any suggestions?
For each single Project Board i can activate the feature without a problem.
Best regards,
Jannis
