Currently I am working on ALM migration to JIRA.
And we will be using XRAY plugin, can any one suggest how can we move Test artifacts of all types of TC's like Automation and Manual from ALM QC.
If you want to create a script or some automated process for this, you can use GrapQL API like this one (https://xray.cloud.getxray.app/doc/graphql/updateteststep.doc.html) to update a Test Step. The attachment for the Step is sent as input using Base64 format.
If you need to add attachments in other places, please search by the name of the Xray object (Test Run, Test Execution, etc.) in the document link; it will show the method that you can use.
Please contact Xray Support (http://Xraysupport.getXray.app) if you need further help.
Thank you.
Rogerio Paiva [Xray Support Team]
Thank you Rogerio for the info, i will try and update at the earliest.
