How to export all issues of a single project to excel file
Rasika Senarath
July 1, 2020
We are in requirement to export all issues of a project and consolidate them in to a single excel file for the ease of sharing between the stakeholders of the project.
Excel file shall include data such as Issue ID, Reported Date, Priority, Reporter, Assignee, Status & Comments in separate columns.
Regards
Tim Straub
Ha @Rasika Senarath ,
you can search for all issues within a project. In the results lists select the columns you want to have in the Excel file usins the button "Columns".
With the action "Export" you will be able to export them to a CSV file (Export >> CSV (Current fields).
Import them into Excel.
Hope this helps.
John Funk
Hi Rasika - Welcome to the Atlassian Community!
Take a look at this free add-on from Atlassian.
https://community.atlassian.com/t5/Jira-Articles/The-add-in-you-ve-been-waiting-for-Jira-Cloud-for-Excel/ba-p/1210420
It will allow you to open all issues in the filter in Excel even if there are more than 1,000.
