I want to have in excel and be able to filter columns based on information placed in each Jira registered
Hello @LUIS MEDRANO
I suggest that you will use Google Sheet which is a better option.
Simply run your JQL and the click on "APPS" and select Google Sheet.
If its the first time you are using it - it will prompt and connection request - approve it and it will open your data in google sheet.
Hello @LUIS MEDRANO
Where you able to handle your issue?
