I need to export more than 1000 issues and I use JIRA6.3.
I changed the value of jira.search.stable.max.results from 1000 to 1200 on advanced setting but the limitation of exporting issues are still 1000.
Please let me know what else I should configure.
Best Regards,
Yoko
Look at https://confluence.atlassian.com/display/JIRAKB/Export+More+Than+1000+Results+to+Excel
There are other parameters to update:
Hi Peter,
I could export more than 1000 issues. Thank you.
Best Regards,
Yoko
