How to export multi-select fields values into single column in csv in jira data center
Lakshmi CH
April 15, 2025
Hi Team,
I am trying to export a report in Jira, but I noticed that the multi-select field generates a separate column for each value. Is there a way to consolidate all the values into a single column for that particular field?
Please find the attached screenshot for your reference.
Akhand Pratap Singh
April 15, 2025
Hello @Lakshmi CH ,
Good day and welcome to Atlassian Community
Seems like it is not possible at the moment (not a native Jira function), there is an open ticket with Atlassian, you vote and add yourself as watcher to track the updates.
Ticket: [JRASERVER-63747] Possibility to export multi-select fields of issue into single column in CSV - Create and track feature requests for Atlassian products.
