Can anyone suggest me to how I extract highlighted epic link (please refer the attached snap below) in power bi to create a dashboard. In Power Bi connector for Jira except epic link all information are available.
Please let me know if anyone help me to fix this issue.
Thanks for your support!!
Hello Umesh @Umesh Bhatt ,
If you use Jira Cloud, Epic link can be found among Custom Fields under the Jira Work Management tab:
If you need further help, please feel free to create a support request and we'll be happy to help.
Luba
Thanks @Liubov Topchyi for help!!
Can you please expand Issue Custom Fields and show me the fields epic link fields to enable on Jira Work Management.
One more point I want to add, If I enable this on Jira Software. So, can I get the epic link details on Power BI using Power BI Connector for Jira.
Your suggestion really matters a lot..
Jira Software is built on Jira Work Management. If you have Jira Software you'll just have one additional tab for the Jira Software with Jira Software related tables. All other tables and fields you can get from the Jira Work Management tab.
Here is the expanded Issue Custom Fields screenshot:
Please let me know if this helps.
Additionally, please feel free to create a support request in our Help Desk: https://aserve.atlassian.net/servicedesk/customer/portal/16
Luba
