How to extract status workflow in every project ? - JIRA Extracted Data
Alvian Rizky Hernanda
May 6, 2024
Hi Everyone, I would like to ask how to extracted status workflow date like picture below. Actually for current condition, the extracted data only showing the created and updated date. Please advise about this condition, thank you in advance.
Status Workflow
Created & Updated Date
Yuliia_Borivets__SaaSJet_
Hi @Alvian Rizky Hernanda
  • If you want to extract info about workflows being created or updated, you can find it in the Jira Audit Log:
  • If you need to get status changes for each issue in your project, you can check Issue History for Jira app from my team and export the info like on the screen:
Aron Gombas _Midori_
You can export your selected issues and their selected fields (columns) plus their full change history to Excel (sample exports) with the Better Excel Exporter app:
Then you can use the Excel filter to limit the view only to those rows where the "Change Field" is "status". Basically you will get the precise list of status changes with who did it ("Change Author") and when ("Change Time").
(Discl. this is a paid and supported app developed by our team. Free for 10 users!)
