How to filter Module custom dropdown based on Component/s selection?
Lacey McDonnell October 28, 2016
We are using the JIRA Native component/s field for our components. We have a custom field called Module for the specific aspect of the component that needs attention.
We have over 100 custom modules in the entire list; only 4 or 5 at a time can apply to any one component.
Can we write a behavior to filter those 100+ values to show only those applicable to the selected component?
I took a peek at Default Values but am not savvy enough to figure it out on my own.
(Adaptavist declined to work on this issue due to staffing/time restrictions in relation to scripting queries and directed me to Atlassian Answers.)
Thanos Batagiannis [Adaptavist]
November 11, 2016
Hi Lacey,
try something like the script below (assign it to Component fields)
def compForm = getFieldById(IssueFieldConstants.COMPONENTS)
def module = getFieldByName("Module")
def componentModuleMappings = [
    "Component B" : ["A", "B", "D"],
    "Component A" : ["A", "I", "L"],
    "Component C" : ["K", "M"],
def selectedComponents = compForm?.value as List
if (! selectedComponents) {
    // no components selected, do something
    compForm.clearError()
} else if (selectedComponents.size() > 1) {
    // more than one components selected, display an error message
    compForm.setError("Please select only one component")
} else if ( selectedComponents.size() == 1) {
    // exactly one component selected, set the available options for the module field
def selectedCompName = selectedComponents[0]?.name
log.debug "Selected Component : ${selectedCompName}"
def moduleOptionValues = componentModuleMappings.get(selectedCompName)
    def optionManager = ComponentAccessor.getOptionsManager()
    def moduleCFConfig = ComponentAccessor.
        getCustomFieldManager().
        getCustomFieldObjectByName("Module")?.
        getRelevantConfig(issueContext)
    def optionsForModule = optionManager.getOptions(moduleCFConfig).findAll { it.value in moduleOptionValues }
    module.setFieldOptions(optionsForModule)
Please let me know if this does the trick. If this does not work please let me know what kind of error you get in your logs and please let me know how you "changed the Component/s field to render as a single select"
regards, Thanos
Lacey McDonnell November 11, 2016
Well, I had removed from WEB-INF the "multiple" line but it looked stupid. So I restored the clause, restarted the instance, and now I have a global behavior instead to limit it to one choice:
def formComponent = getFieldById(getFieldChanged())
// if it's a list it has more than one value
if (formComponent.getFormValue().getClass().toString().contains('List')) {
    def List compos = []
    formComponent.getFormValue().each{obj->
        try{
            def objint = obj as int
                    compos.add(objint)
        catch(e){}
    if (compos.size() > 1){
    formComponent.with {
        setValid(false)
        String s = "Please select only one component."
        setTitle (s)
        setHelpText("<div class=\"warningBox\">$s</div>")
else {
        setValid(true)
        setTitle ("")
        setHelpText("")
Same thing for fix version only where you see "Component" it says "fixVersions"
As for MODULE:
This is closer than I got. At least it has an effect at all - unfortunately, that effect is to completely remove all values from Module smile
It reads as an error on def selectedCompName = compForm?.value[0].name as List where it couldn't find a matching method java.lang.Object#getAt(int) ....
The only line in the atlassian-JIRA log I see that is remotely related to my issue update attempt is:
2016-11-11 15:50:10,491 http-bio-8080-exec-2 WARN Lacey87143 950x28024x2 gk1jak 10.255.250.124 /secure/AjaxIssueAction!default.jspa
November 13, 2016
Ok, Lacey what I can propose to leave the components field as a multi-select list and display an error message if more than one component is selected (with a behaviour),
I updated the script above. Hope that is better.
Lacey McDonnell November 14, 2016
That script is what I had but applied to a separate Behavior called "Defaults" cheeky But now I see how to tie it into another rule! Thank you smile
Unfortunately, Module is still coming up blank, and it throws an error on "compForm?.value[0].name"
November 14, 2016
Hi Lacey,
The error you see is a static type checking error, ignore it. The Module will come blank if there is not the available Component - Module pair in the componentModuleMappings map.
Just added a debug message on the script above, so enable logging and check your log files.
That tipped me off - the spaces.
I had
" LOB - UK - Small Office ": [" Document ",
    " Forms",
    " Performance ",
    " Premium Summary ",
    " Rating ",
    " Surcharges ",
    "Tables ",
    "Transactions ",
    " UI "],
I took out the spaces and all is well
Have I told you lately that I love you????? :* THANK YOU
November 14, 2016
Glad that helped to sort it out, and for your kind words.
Lacey Also October 9, 2020
@Thanos Batagiannis [Adaptavist]  Here's an updated version of your solution for recent Jira API
import com.atlassian.jira.issue.IssueFieldConstants
import static com.atlassian.jira.issue.IssueFieldConstants.*
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
def customField = customFieldManager.getCustomFieldObject(module.getFieldId())
"Issue Data":
"Training",
"New Field"
"Projects":
"Training",
"Other"
// none selected, do nothing
else if (selectedComponents.size() >1) {
// more than one, throw an error
compForm.setError("To best service your request, please select only one Component. Each Component should have its own ticket. This helps us group similar incoming requests for review and approval.")
else if (selectedComponents.size() == 1) {
// exactly one selected, set available options for Modules field
def moduleCFConfig = customField.getRelevantConfig(getIssueContext())
def optionsForModule = optionManager.getOptions(moduleCFConfig).findAll {it.value in moduleOptionValues}
Lacey McDonnell November 9, 2016
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.component.ComponentAccessor;
def optionsManager = ComponentAccessor.getOptionsManager()
def formModule = customFieldManager.getCustomFieldObject('Module')
def projectComponentManager = ComponentAccessor.getProjectComponentManager()
def components = projectComponentManager.findAllForProject(issueContext.projectObject.id)
def config = formModule.getRelevantConfig(getIssueContext())
def options = optionsManager.getOptions(config)
if (components == 'LOB - Classic CPP') return formModule = (options.findAll {it.value in
['Document','Forms','Performance','Premium Summary','Rating','Surcharges','Tables','Transactions','UI']})
if (components == 'LOB - Commercial Package') return formModule = (options.findAll {it.value in
This says correct and it is definitely not working. @Thanos Batagiannis [Adaptavist] lol any ideas?
November 10, 2016
Hi Lacey,
As far as I understand let's say you want when Comp A is selected the available for selection options for the Single Select Module Custom Field to be A, B, C and if the Comp B is selected then available options to be A, B.
But the components is a multi select therefore what options you expect the field Module to have when Comp A and Comp B are selected as components ?
Lacey McDonnell November 10, 2016
I changed the Compoent/s field to render as a single select smile
def formComponent = getFieldById("components")
Object componentFormValue = formComponent.getValue()
if (componentFormValue == 'LOB - Classic CPP')
else if (componentFormValue == 'LOB - Commercial Package')
still not working lol
November 10, 2016
Another one question... So you want to fill the Module Select List with default options or to change the available options ? (something like a cascading select list where the right options depend on the left selected option)
I want to change the available options like a cascading select.
(i.e. we have custom field MODULE values 1-100. if we select JIRA native field COMPONENT/S value A I want to Module dropdown to only show values 2,6,77,90),
Vivek Lakshman
March 17, 2021
Hi @Thanos Batagiannis [Adaptavist] ,
You are deserving of even more love than Lacey gave you!
I love you too!
Atlassian, Team '25 Europe, Atlassian conference, AI-powered teamwork, Atlassian events, keynote speakers, Barcelona tech conference, Atlassian Williams Racing, Carlos Sainz, Jenson Button, Mike Cannon-Brookes, Anu Bharadwaj, Atlassian Rovo
Atlassian Williams Racing is coming to Team '25 Europe 🏎️
Discover the teamwork and precision behind success on and off the track. See how this high-performing team makes the impossible possible. Be one of the first 100 customers to register for a chance to win 2 tickets to an Atlassian Williams 2026 race.
Register now
