How to filter epics by tasks, issues id?
Mohasin Sayyad May 24, 2022
Need to filter Epics by tasks/issues in current sprint
I want to select epics based on the tasks/stories in the current sprint
Bandarupalli Sai
 You can use this filter
issue in childIssuesOf("EPIC-123") AND Sprint in openSprints()
Bandarupalli Sai
Let me know if this helps for you!
Bandarupalli Sai
Do you want to filter all the stories or tasks that are linked to a specific epic?
Mohasin Sayyad May 26, 2022
No,
For Example, I have multiple stories/tasks/bugs in a sprint and all these are from different epics.
After sprint closure I need to know which epics are done in the sprint.
Currently I am doing it manually, I go through each story/task, Then I select it's Epic and check the status.
I wanted to know Is there a filter which let us list the Epic from the story/task in the current sprint?
Bandarupalli Sai
@Mohasin Sayyad You can use the below filter to find all the epics that are linked to story or task which are in the current active sprint
project = ABC AND issueFunction in linkedIssuesOf("Sprint in openSprints()", "has Epic")
You to fetch the epics after the sprint is closed then you have to replace open sprint with the sprint ID in the above filter.
