Greetings,
I'm trying to generate chart or a report by grouping all 2018 Q1 issues by Organizations field, for example company A created N number of issues, company B created M number of issues etc. But Organizations field is not available among list of filters in dashboard gadgets (for example Pie Chart). So I searched for 2018 Q1 issues and then exported the result to an Excel file, but the resulting excel file contained numbers (probably ids) in the Organizations column instead of Organization names, how can I generate the report/chart I need?
Hello @Enkhtaivan Ganbat,
There is an open feature request about the CSV export: JSDCLOUD-5600. The only workaround seems to be using the API.
Hope this helps,
- Manon
