How to filter to issues without Original estimates but do have subtasks assocaited with the parent issues?
Yogesh
I am trying to create a filter using JQLT. I want to fetch all Parent issues having original estimate=0 and subtasks associated with the same.
Jobin Kuruvilla [Adaptavist]
November 30, 2011
Which version of JQLT are you using? Try the following:
(originalEstimate = 0 and issuetype in standardIssueTypes())OR parent(originalEstimate =0)
Yogesh
I am having JIRA 4.2.1B588.
The above command is not working in that.
November 30, 2011
Which version of JQLT are you using? And what is the error you are getting? vesion 2.2 should support both the queries and it is compatible with JIRA 4.2.x
Yogesh
Where can I see the version of JQLT?
November 30, 2011
You can find it under Administration > Plugins > User-Installed Plugins > JQL tricks Plugin
Yogesh
It's a commercial plugin and I am sure we never bought the license. I am using native JIRA JQLs.
November 30, 2011
Hmm, Sorry I got confused because you mentioned using JQLT in your question!
Yogesh
November 30, 2011
To filter issues having subtasks, try:
issue in hasSubtasks()
Yogesh
OR
How to fileter all parent issues having subtasks?
