How to find Jira Projects not assigned to a Issue Level Security Scheme
I am trying to locate all projects that are not using any sort of defined Issue Security Scheme? Is this possible using JQL or must this be a DB query?
Arthur Gonçalves
May 22, 2015
Hey there,
You can run the following query on JIRA DB:
select pname from project
where pname not in
select pj.pname from nodeassociation na
inner join issuesecurityscheme iss on iss.id = na.sink_node_id
inner join project pj on pj.id = na.source_node_id
and na.source_node_entity = 'Project'
where na.sink_node_entity = 'IssueSecurityScheme'
-- Arthur Gonçalves
