I am trying to find a JQL query that can list issues in a specific project that has a changed duedate using JIRA 6.2.1. Looking at https://confluence.atlassian.com/display/JIRA/Advanced+Searching#AdvancedSearching-CHANGED this could be useful, but i am guessing this feature does not exist in 6.2.1? Could this feature be used in JIRA 6.4?
Benito, we are attempting to see issues with a postponed due date (which for our organization is crucial as we don't set these duedates ourselves, our 3rd parties do). It would be nice to have a agile board with only overdue issues, but querying all issues for any update would be heavily misleading. Is there a plugin/addon that can do this?
JIRA 6.2 should have the changed operator according to the user's guide of JIRA 6.2.
However, the page also says that
(Note: This operator can be used with the Assignee, Fix Version, Priority, Reporter, Resolution and Status fields only.
So, I suppose you can't use it for duedate.
Hi Jonas,
Another possible thing you could do is use the "Updated" on the JQL. That would bring all the changes to issues though, not only to that field.
