How to fix the discordant URL encoding between JIRA and Fisheye?
ComeR
September 20, 2011
The URL encoding of web links for Git Repositories in Jira is different from the URL encoding used by Fisheye. As a result, the links to the modified files for a ticket that are listed under the "Git Commits" tab are broken.
For instance, if I have a repository MyGitProject with a path 'c++/someFile.cpp', the URL in Jira will be:
http://fisheye-server:8060/browse/MyGitProject/c++/someFile.cpp#841e1caa1ce
But the correct URL for fisheye should be:
http://fisheye-server:8060/browse/MyGitProject/c%2B%2B/someFile.cpp#841e1caa1ce
(fisheye encodes the 'c++' part of the URL, that becomes 'c%2B%2B')
My guess is that I would need to replace the '${path}' in the "File Modified Format" with somethin like '${urlEncodedPath}' in the 'web linking' section of the repository, but I couldn't find the relevant variable (or even the relevant part of the documents)
Thanks for any help
Chii
September 27, 2011
This is a known bug in the Jira FishEye Plugin , see https://studio.plugins.atlassian.com/browse/FISH-453
