×How to fix warnings after JIRA Upgrade from version 7.5.0 to version 7.9.2.
1. Database: Supported database;
Postgres 8.4.11 is not supported and need to migrate to supported database version.
2. Database: Your database is using unsupported collation
Your postgres72 database is currently using an unsupported collation: en_US.UTF-8.
change to POSIX_UTF-8, C.UTF-8, C or POSIX
@Jeannine Gentleman, yes... you definitely want to update your database. PostgreSQL 8 is pretty old. Since you've gotten to Jira 7.9.2, you'll probably want to go all the way to 9.6.x so you won't have to go through this for a while.
The unsupported collation is also a bit of a Big Deal; for the most part (from what I gather) things work well until they... don't... and then it usually ends in tears.
Also, when migrating, I'd suggest that you dump your database but do NOT add the "drop database" and "create database" options to the dump. Rather:
For reference the SQL statements I use routinely when creating the database are:
CREATE
ROLE jira;
ALTER
ROLE jira LOGIN;
ALTER
ROLE jira
PASSWORD
'jira'
GRANT
jira
TO
postgres;
CREATE
DATABASE
jira
WITH
ENCODING
'UTF8'
LC_COLLATE=
'C'
LC_CTYPE=
'C'
TEMPLATE=template0 OWNER jira;
GRANT
ALL
ON
DATABASE
jira
TO
jira;
Note: the "GRANT jira to postgres" is an AWS RDS thingy; it won't hurt on a local DB but when doing all these steps as user "postgres" on RDS, it fails without that step. If you're running a local instance of PostgreSQL you don't need that step
Also, while they don't "officially" support them, I do take the time to load the latest JDBC drivers from PostgreSQL as I have found some significant performance improvements there.
1st warning is fixed by upgrading our PostgreSQL driver to the latest version; downloaded postgresql-9.4-1206-jdbc41.jar from https://jdbc.postgresql.org/download.html
2nd warning is being worked on "unsupported collation: en_US.UTF-8"
You could try and upgrade your PostgreSQL driver to the latest version and see if that does it, if not then you would have to upgrade to a supported version, see Supported platforms.
