I am looking how to restrict the creation of a story in a project only the project leader. But other users must have the possibility to create bugs.
I have found how to restrict to creation of tickets to the project leader but it also forbid the creation of bugs.
Thank you
Sadly it's not possible in JIRA. When a group/role has the permission to create an issue, it could create EVERY type of issues available for the project.
Atlassian JIRA issue : https://jira.atlassian.com/browse/JRA-5865
Discussion: https://answers.atlassian.com/questions/33259
Thank you for your answer.
I thought to a : I have tried to add a condition on a transition in the workflow (on a transition "TODO" from a state "NEW"') but it has not worked. Probably I not not have this correctly, somebody now how to say: "This transition may be done only may the project leader"
Or maybe my test has not worked because I am administrator and I can do anything event if I am not the project leader ?
It's a bit ugly but you can use a validator on the Create transition. With a different workflow for Story and Bug
