How to generate Thread Dump and Heap Dump for JIRA using shell scipt
AKASH BHARDWAJ
Hi All,
I need to write shell script which should generate Thread dump & Heap dump pragmatically using Shell script.
These needs to be take with time span of 10 millisecond and in number of 5.
 I know i need to capture JIRA PID and then create Directory where these files will be dumped.
Any help will be aprreciated.
Akash
noamdah
September 14, 2016
You can use the kill -3 command:
kill -3 <PID>
Run it in a loop for 5 times with 10sec wait each time.
This command will write the thread dumps to the catalina.out file,
Copy the relevant lines from that file to the designated file.
