How to generate work load report in Jira?
Admin Invent2
January 1, 2024
Hi, I'm using Jira free trial
how to generate work load report in jira work management? I would like to know every member team doing howmany task in certain period.
Berat Altunhan
You can create filter about the issues for which they are assignee and than you can create dashboard. Use ''Assignee Statistic'' on dashboard.
You can use JQL or Created Date field to give a specific time interval.
JQL Function: https://support.atlassian.com/jira-software-cloud/docs/jql-functions/
