I have created a web-panel plugin for issue using Velocity, this panel reads some rest data (provided by the plugin itself) with JavaScript. Now I would like to add some details of the issue (eg. Issue Type, Issue Priority, Issue Number). Based on this issue details the web-panel will display different output.
<web-panel key="Issue plugin" location="atl.jira.view.issue.right.context">
<resource name="view" type="velocity" location="/templates/view.vm"/>
</web-panel>
Many thanks for any hints/help
Resolved by adding context-provider class to web-panel definition in atlassian-plugin.xm
