×You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Seeing the response you get, you don't have Jira administrator rights on your instance.
You need to have these permissions to use the API call @Tuncay Senturk _Snapbytes_ mentioned to you.
Could you verify that you have full Jira Administrator permissions?
