  • Community
  • Q&A
  • Jira
  • Questions
  • How to get all issues in project , and how to get issues with status in progress script runner jql
Karim Belhadj
Hello team
i would like to get all issues in one project and to compare the number with issues in the same project which has the status in progress. Thanks
Gezim Shehu [Communardo]
Take a look at the script. I think this gets the job done for you.
In case you want to further process the issues, you can use the optional loop
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.event.type.EventDispatchOption
import com.atlassian.jira.issue.index.IssueIndexingService
import com.atlassian.jira.util.ImportUtils
def sdUser = ComponentAccessor.getUserManager().getUserByKey('robot')
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchProvider = ComponentAccessor.getComponent(SearchProvider)
def query1 = jqlQueryParser.parseQuery("project = XYZ")
def query2 = jqlQueryParser.parseQuery("project = XYZ and status =\"In Progress\" ")
def results1 = searchProvider.search(query1, sdUser, PagerFilter.getUnlimitedFilter())
def results2 = searchProvider.search(query2, sdUser, PagerFilter.getUnlimitedFilter())
log.warn("All issues=" + results1.total)
log.warn("In Progress Issues=" + results2.total)
//if you want to do something with the issues, use the following loop
results1.getIssues().each() {
    documentIssue ->
        def issue = issueManager.getIssueObject(documentIssue.id)
        //something goes here
//x
Karim Belhadj
@Gezim Shehu [Communardo] , first of all thank you for your reponse , but ecxcuse i make my userByKey and project key , but always results = 0 for all issues and in progress.
Karim Belhadj
def sdUser = ComponentAccessor.getUserManager().getUserByKey('Spectrum Admin')
log.warn("the user key is " + sdUser)
The user key is always null.
Are you using the username or display name of the user?
Usernames don't have spaces
Like # people like this
Karim Belhadj
it works fine . I solve it .
Glad to help
