How to get all sprints in project using JIRA REST API
lokesh cherukuri
Is there anything something like "http://www.example.com/jira/rest/agile/1.0/sprint?project=XYZ", to retrieve all the sprints in a project.
JIRA platform api can retrieve projects info and JIRA software API can retrieve sprints for a given board. But i need sprints for any given project (combination) or atleast boards for a given project so that i can retrieve sprints in those boards later
8 votes
Matthias Gaiser [K15t]
Just in case you are still looking (or someone else is looking like me), you can get all the boards valid for a project with the same request to get all boards (see https://docs.atlassian.com/jira-software/REST/cloud/#agile/1.0/board-getAllBoards).
You just have to specify as query argument (projectKeyOrId) your project. Afterwards you can use https://docs.atlassian.com/jira-software/REST/cloud/#agile/1.0/board/{boardId}/sprint-getAllSprints to get all the sprints for a board.
Vijay Anand July 21, 2017
This will include sprints not only for the project in question but all projects that are part of the board isn't it?
As far as I understand, the sprints belong to the board and not the project. The mentioned method will list the sprints of the current board.
And these sprints can be used in multiple projects.
senduran June 12, 2020
I used something like this and receive all the sprints for a project.
but you cannot find the greenhoppers documentation now. it has been deprecated. but the UrL i mentioned below is still working.
https://codegen.atlassian.net/rest/greenhopper/latest/integration/teamcalendars/sprint/list?jql=project=XYZ
SivaKumar Manickam
June 25, 2020
what is the date format in the response?
senduran September 2, 2020
it is a hashcode and you cannot extract date from this. so u can get date for one sprint only.
Alyssa Freeze
September 30, 2021
@senduran Thank you!!
but you cannot find the greenhoppers documentation now. it has been deprecated. but the url i mentioned above is still working.
krishan avtar gaur
November 10, 2020
How can we get Status in side sprint ?
Hector Agudo Mantilla
March 5, 2018
Hello
You can see this link to resolve it:
https://docs.atlassian.com/jira-software/REST/7.0.4/#agile/1.0/sprint-createSprint
Kind regards
Rostyk Chuma
January 27, 2020
You can get SprintManager bean and then get list of sprints.
private static SprintManager getGreenHopperRapidManager() {
OsgiContainerManager osgi = ComponentAccessor.getComponentOfType(OsgiContainerManager.class);
if (osgi == null) {
java.lang.System.out.println("OSGI Not Found");
return null;
Bundle[] bundles = osgi.getBundles();
for (int i = 0; i < bundles.length; i++) {
Bundle bundle = bundles[i];
if ("com.pyxis.greenhopper.jira".equals(bundle.getSymbolicName())) {
BundleContext bctx = bundle.getBundleContext();
try {
ServiceReference[] refs = bctx.getAllServiceReferences(null, null);
if (refs != null) {
for (int j = 0; j < refs.length; j++) {
Object prop = refs[j].getProperty("org.springframework.context.service.name");
if ("com.pyxis.greenhopper.jira".equals(prop)) {
ApplicationContext appCtx = (ApplicationContext) bctx.getService(refs[j]);
appCtx.getBeansOfType(SprintManager.class);
return (SprintManager) appCtx.getBean("sprintManagerImpl");
} catch (InvalidSyntaxException e) {
e.printStackTrace();
return null;
Hany Hassan August 27, 2017
To get list of rapidviews in a project use :
.../rest/greenhopper/latest/rapidviews/list?projectKey=PKY
Wilian Ricardo
October 3, 2018
Muito obrigado...
Like Stan the man likes this
