Hello everyone,
I'm fairly new to Groovy for Jira, and I came across a strange case
I need to know if an user has rights to a given project/issue. I then created following code :
But when I execute I got
groovy.lang.MissingMethodException: No signature of method: static com.atlassian.jira.user.ApplicationUser.hasPermission() is applicable for argument types: (com.atlassian.jira.security.plugin.ProjectPermissionKey, com.atlassian.jira.issue.IssueImpl) values: [BROWSE_PROJECTS, BLA-136] Possible solutions: hasPermission(com.atlassian.jira.security.plugin.ProjectPermissionKey, com.atlassian.jira.project.Project), hasPermission(com.atlassian.jira.security.plugin.ProjectPermissionKey, com.atlassian.jira.issue.Issue), hasPermission(com.atlassian.jira.permission.GlobalPermissionKey) at Script460.run(Script460.groovy:12)
I don't know how to hop from com.atlassian.jira.issue.IssueImpl to com.atlassian.jira.issue.Issue. It's the same if I try to load the project, I even tried mutableIssue but still the same result. I tried to use directly issueobj but same result too.
Do you have any indication or documentation I may have missed on how to convert that into the type I need ?
import com.atlassian.jira.security.PermissionManager
import com.atlassian.jira.security.plugin.ProjectPermissionKey
import com.atlassian.jira.user.util.UserManager
IssueManager issueManager = ComponentAccessor.getIssueManager()
UserManager userManager = ComponentAccessor.getUserManager()
PermissionManager permissionManager = ComponentAccessor.getPermissionManager()
Issue issue = issueManager.getIssueObject('ABC-123') as Issue
ApplicationUser appUser = userManager.getUserByName('dummy')
boolean hasPerm = permissionManager.hasPermission(new ProjectPermissionKey("BROWSE_PROJECTS"), issue, appUser)
No, it will work and without "as Issue"
Your errors are:
- wrong way of getting issue object
- wrong way of checking permissions.
ApplicationUser - is abstract and don't have hasPermission function. You have to add new variable with object type Application User, what I made at line 14.
And then you have to use permissionManager, that checks permissions of user
