How to get checklist values and use the IN equivalent of SQL commands
Marc Jason Mutuc
January 14, 2015
I'm trying to figure out how to check if Check List Field has a specific value ticked.
Say Check List Field = CHECK1
Opions are OPT1, OPT2, OPT3.
I want to check if OPT2 is ticked and return a value. Thank you!
David _old account_
January 15, 2015
if (issue.get("customfield_12345") == null)
	return null;
if ("OPT2".equalsIgnoreCase(issue.get("customfield_12345").getValue())
  return "OPT2 checked";
where 12345 is the numerical id of the CHECK1 field (see the doc for an explanation of how to find it).
Marc Jason Mutuc
January 17, 2015
Thank you David! Appreciate your answers. What if I duplicate named options? How to I distinguish between them? Is there also a syntax for it like below: cfValues['Custom Field Name'][0].getValue() == 'OK' cfValues['Custom Field Name'][1].getValue() == 'OK' cfValues['Custom Field Name'][2].getValue() == 'OK' cfValues['Custom Field Name'][3].getValue() == 'OK' cfValues['Custom Field Name'][4].getValue() == 'OK' cfValues['Custom Field Name'][5].getValue() == 'OK'
Marc Jason Mutuc
January 17, 2015
also, I got the following error on the logs (I just checked now since I was confident is was going to work, sorry.): [innovalog.jmcf.fields.CalculatedTextField] CalculatedTextField: error evaluating formula: Sourced file: inline evaluation of: `` if (issue.get("customfield_13811") == null) return null; if ("Received". . . . '' : Error in method invocation: Method getValue() not found in class'java.util.ArrayList'
David Fischer
I didn't get that your field was a multi select field. In that case, issue.get(...) will return an array list of Option objects. So you'll need to iterate over that array : for (Option o : issue.get(...)) {
if (o.getValue().equals("...")) return "...";
Marc Jason Mutuc
January 20, 2015
Tried the following which is the first item in the checklist : <!-- @@Formula: if (issue.get("customfield_13811") == null) return null; for (Option o : issue.get("customfield_13811")){ if (o.getValue().equalsIgnoreCase("Received")) return "OK"; } --> Got the following error in the logs [innovalog.jmcf.fields.CalculatedTextField] CalculatedTextField: error evaluating formula: Sourced file: inline evaluation of: `` if (issue.get("customfield_13811") == null) return null; for (Option o . . . '' : Class: Option not found in namespace How do you detemine the letter o?
David _old account_
January 20, 2015
Can you try by simply removing "Option" (keep "o : ")?
Marc Jason Mutuc
January 22, 2015
Still not working. :(
Marc Jason Mutuc
January 22, 2015
By the way, the field is a checklist. Although, I think that's the same with multiselect.
David _old account_
January 22, 2015
"Not working" doesn't really help... Any error in the logs (if so, it has to be a different error)?
