How to get custom field value using Jira workflow validator
이정왕 March 8, 2023
I am using Jira Cloud.
How to get custom field value using scriptrunner in Jira workflow validator?
I need to use Jira expressions.
Thank you.
2 accepted
Alex Koxaras -Relational-
Hi @이정왕
Jira expressions can be found here https://developer.atlassian.com/cloud/jira/software/jira-expressions/
But it would be great if you could share with us, what are you trying to accomplish. Maybe we can help you find a solution.
이정왕 March 12, 2023
I'll be waiting for @Alex Koxaras -Relational-  reply.
Have a nice day ~!
Thank you.
@이정왕 kindly check this page for examples https://docs.adaptavist.com/sr4jc/latest/features/workflow-extensions/validators/example-validators
The logic is that you've got to find your custom field id and compare it with a value. Your requirement is "So if its value is Y, it prevents creating an issue.". That could be entered as:
issue.customfield_XXXXXX.value == "Y"
Something along these lines.
이정왕 March 13, 2023
Hi @Alex Koxaras -Relational- ,
This means a lot to me.
Thank you for your reply.
@이정왕 if you got this thing working, kindly mark my answer as resolved, in order to help others in the community with similar questions. Thank you!
이정왕 March 9, 2023
I have one more question.
How to call Rest api for custom field value in Workflow Validator in Jira Cloud?
 Thank you.
Oliver Siebenmarck _Polymetis Apps_
March 13, 2023
Hi @이정왕 ,
In Validators (and conditions for that matter), you cannot use the REST API to load any data. Unfortunately, that also means that there is no way to read the actual asset data.
이정왕 March 13, 2023
Hi @Oliver Siebenmarck _Polymetis Apps_ ,
I couldn't have done it without you.
Thank you~!
이정왕 March 9, 2023
Hi, @Alex Koxaras -Relational-
Thank you for your reply!
What I'm trying to achieve is:
First, read the value of one custom field.
Read the value from the asset object connected field to the field called the request target and put it into another custom field value.
It is by using a script runner in the validator in the workflow.
Thank you.
FREE
