How to get in how many projects Easy Agile programs for jira cloud
Rajasekhar
May 12, 2025
How to get details in how many projects a Plugin is used in Jira Cloud instance.
R
Henri Seymour {Easy Agile}
Hi R,
Easy Agile Programs uses Jira boards to pull issues into a Program.
  • A board can contain issues from more than one Jira project, but boards on Jira Cloud have a "home" project.
You can check which Jira boards are used in the app by checking the Edit Program menu for each Program. The configuration for each Program will include:
You'll then be able to open these boards in Jira to check which projects they use.
Thanks for reaching out to our support team too! We've been able to share a bit more information based on analytics for your app license in that conversation.
Henri, Support Engineer @ Easy Agile
Dilip
May 12, 2025
check this article that handle the similar query: https://support.atlassian.com/jira/kb/how-to-assess-app-or-plugin-usage-in-jira/
Additionally, you try the market place app "App Usage for Jira" which can provide insights into how apps are being used across your Jira instance
