How to get issue id from Jira in Python?
John Paco
February 2, 2022
https://confluence.atlassian.com/jirakb/how-to-get-issue-id-from-the-jira-user-interface-827341428.html
This Link describes how to get issue id from the Jira User Interface.
Is it possible to get This id in Python with using Jira-Rest-Api?
svegesna
September 20, 2023
I'm using JIRA python library
from jira import JIRA, JIRAError
You can use search_issues and try ti get the key using issue.key.
def getIssues(self):
query = "project='Your Project'"
issues = self.jira.search_issues(query, maxResults=False, fields=['key'])
for issue in issues:
keys = {issue.id: issue.key}
return keys
Pramodh M
Hi @John Paco
Welcome to the community 🙂
Here's the python wrapper you can play around to get the data
https://atlassian-python-api.readthedocs.io/
Let me know if you have any queries
Pramodh
