How to get issue key in clone issue and links post function?
Tsol
March 30, 2014
Hi everybody,
i'm using clones issue and links post function from groovyrunner plugin. I want to pass the issuekey in the summary of new linked issue.
In additional issue actions field i have the following
log.warn("key: " + issue.getKey())
But from logs i see that i get a null value.
Any idea how can i get the issue key?
Thanks in advance
JamieA
March 31, 2014
try:
transientVars["issue"].key
This should give you the key of the issue that you are cloning from.
Tsol
March 31, 2014
That's it.
Thanx a lot
Dan Goldman
October 8, 2014
What if you wanted to get the key of the issue you have just created as result of cloning? That is, the new issue key?
JamieA
October 9, 2014
In recent version it's available as *sourceIssue*
Brian Bishop
July 24, 2015
When I try to access this I get a null pointer exception log.debug("DBG: issue key is " + transientVars["sourceIssue"].key)
JamieA
July 27, 2015
Brian - what version of the plugin are you using?
JamieA
July 27, 2015
