All you need to do is run a query in Jira - don't bother messing with the database, a simple Jira search can do it already.
Once you've done the search in Jira, look at the top of the screen for the various displays for it - if you want to get it into another application, the XML link is very useful. If you need to get a range of different queries, look carefully at the URL for the XML - it will contain the id for a saved filter, or a series of parameters defining your search.
Hooking up something to try to read via SQL is a lot more complicated, less flexible and pretty much pointless.
Thanks Luzia. I have one question. Using SOAP api we cant able to get all the issues ? (without filter or search issue)
Thanks Nic!!!!
Yeah, I can't find information about the API of 3.12 anymore.
I'm sure you can connect your php script to JIRA's db and get the info you need.
Hi Luzia,
Thank you very much. Please guide me, how to connect php with jira db?
Don't exactly remember how is the database on 3.12...but you should be able to find something like
select * from jiraissue where projectkey = <something>
There are just two tables you're interested in, and I'm pretty sure the projects are in a 'projects' table, and the issues are in the 'jiraissue' table
Hi Luzia,
I already tried with SOAP API via PHP. Using getComponets() and getProject() we can able to lis the existed components and projects. But i cant able to list the issues unser any component or project. I am realy appriciate your answer.
Hi Luzia,
Thanks for your update. Your answer seems SQL query. But How can i use this query using PHP?
