×I have created a classic project with SCRUM template, I want to see the Roadmap menu for this project which is not visible,
Is this feature exclusively applicable only for Next gen projects ? or do we have any configurations to enable it for the project.
Hi @Eshwar Chand Ranga ,
As @Jack Brickey mentioned, the roadmap is only available for NG. There is, however, an open Suggestion to add it to the Cloud version for classic projects. You can vote for and follow it here:
There may be a server version of this request as well, I'll see if I can find it.
-Scott
correct NG only at this time. i haven't seen any commitment to move to classic.
