Hi Team,
I would like to know how we get the workflow transition name,
I am trying to update the custom field when workflow transition action is performed.
def eventTypeManager = ComponentAccessor.getEventTypeManager()
def eventTypeName = eventTypeManager.getEventType(event.eventTypeId).getName()
log.info('Event Type Name:' + eventTypeName)
if(eventTypeName == 'Generic Event' && transitionName == 'Refresh')
//Update custom field value
else{
exit
hello @Teja ,
You could use the transition id. If the name of the transition change, the Id won't.
You can easily find the Id of you transition by going in workflow edition mode:
Thanks for your reply!
I am having a hard time getting the code for the transition ID, any idea?
@Teja what do you mean by "having a hard time " ?
I tried the below code, it works for all the transitions, I want this to run on a particular actionId is 591
def actionId = 591
def issueService = ComponentAccessor.issueService
def user = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def issueInputParameters = issueService.newIssueInputParameters()
def validationResult = issueService.validateTransition(user, issue.id, actionId, issueInputParameters)
if(eventTypeName == 'Generic Event' && validationResult)
//update
@Teja ,
The solution in that case would be :
Yep I have been trying the solution of getting transientVars, but could not able to resolve No such property: transientVars for class
int actionId = 591
def workflow = ComponentAccessor.getWorkflowManager().getWorkflow(issue)
def wfd = workflow.getDescriptor()
def actionName = wfd.getAction(transientVars["actionId"] as int).getName()
if(eventTypeName == 'Generic Event' && actionName == "Refresh")
//update
Error
groovy.lang.MissingPropertyException: No such property: transientVars for class: Script63
