How to give an issue a priority?
Kelly Hayes
February 19, 2016
I am new, so maybe I am missing something, but I don't see where I can give an Issue a priority. I even created custom priorities and colors, but now i don't know how to set.
thanks!
Steven F Behnke
February 19, 2016
The field needs to be available on the screen either assigned to the operation you're trying to use it with (Create, Edit) or the action you're trying to use it with (Resolve Issue, Reopen Issue).
Boris Georgiev [Appfire]
February 21, 2016
You can also use the "Where is my Field" feature to discover why you can't see some field on a screen - look at the top right corner of the forms for a button called "Were is my field")
Kelly Hayes
February 23, 2016
Thanks. Since I was not admin, I had a hard time with this. Fixed!
