I need to move a single project from another instance to JIRA OnDemand, without displacing existing projects.
How do I do this?
I'm afraid that there is no Project Importer on OnDemand as per OnDemand restricted functions
As a workaround you could export into a local instance, perform the import and import back to OnDemand. Basically it is like How to Merge Two JIRA OnDemand instances
See more details on this previous Answer: https://answers.atlassian.com/questions/304192
cheers
