Currently im only able to import one JIRA business project into another software project, but what do i need to do to be able to import it into another JIRA business project?
Hello @Yasmeen Odeh and welcome to the community!
If you are willing to try a third-party app, you could try our app Deep Clone for Jira. Deep Clone allows you to easily clone issues between projects, including all fields, comments, attachments, and more. It provides a simple way to duplicate projects or migrate issues without needing to manually export and import data via CSV. This solution is especially handy if you're already using Jira and want a direct method for copying data.
Hellon @Yasmeen Odeh
If you're seeking for an easy way to clone all your issues from one projet to another, you can try our app Elements Copy & Sync that allows you to clone and sync a full hierarchy of issues with all their content (summary, description, custom fields, comments, attachments, etc).
You can check our guide here.
The app is for free during 30 days (and it stays free under 10 users).
Welcome @Yasmeen Odeh
You need to bulk move the issues from that project to the new one.
Navigate to Issues and then click on three dots and click Bulk change issues and then for the action select Move Issues. Choose your new project as the destination.
Hi @Yasmeen Odeh ,
Welcome to the community !!
Did you try CSV import ?
https://support.atlassian.com/jira-work-management/docs/import-data-into-a-business-project/
Thanks @Rilwan Ahmed I'll try it, but i thought since the project is already on JIRA, there would be a way to import it directly into another project, rather than export it as CSV and then import it again!
You can use bulk edit and do the bulk move
https://support.atlassian.com/jira-service-management-cloud/docs/edit-multiple-issues-at-the-same-time/
